I have a Motorola L603 phone witch comes with a base with handset and two extension handsets. I want to add a third extension handset. Can it be done and if it can be done, how do you go about adding the 3rd handset?
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
SOURCE: Motorola 580 handset not working
are these phones registered to your base? scroll around in the menu until you come to register and press the "-" key. then quickly press and hold the page button on the base unit. you will here the phone beep. should work now
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: My handset won't charge
Try charging it in a different cradle if you have more than one handset. This has happened to me where a particular base will not charge a particular phone. Once charged elsewhere the problem resolved.
SOURCE: PROBLEMS with phone
Had the same issue. I have two units each with a handset, and one handset went to "out of range" status and stayed that way even after recharging. I tried to register it with that base and no luck. I then tried to register it with the other base and it worked. Then I tried to "swap" the handsets and no luck - it seems that the registration process on the one unit is toast so now I can only use the handsets with one of my two base units.
I have tried handset "swap" but that does not work.
