Items in the top knife cleaning rack are not getting cleaned.. otherwise, works great.
SOURCE: Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food
or residue from the detergent. A water pressure problem may be the
culprit. You may need to replace the water intake valve. Another common
problem is mineral build-up. If your house has hard water, the mineral
build-up can clog the water jets. Clear each jet with a wire or pin,
and run an empty load with some vinegar in the detergent dispenser
about once a month.
Sometimes, the dishwasher has problems draining properly. There could
be a clog in the drain hose, or a problem with the pump. It's also
possible that the dishwater is getting too sudsy, and sensors in the
washer aren't detecting the soap foam as water. This causes it to shut
down the drain cycle too early. Just use less detergent.
SOURCE: Upper rack dishes not cleaning well
Yes, run an empty load with 1/4 cup vinegar. It sounds like there is mineral build up in the arm. Try to take the arm apart that supplies water to the top rack of the dishwasher. You can soak this in vinegar water once removed.
SOURCE: will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water
shut-off valve (located under the sink) is open. If you get water to
the dishwasher, but there is still no water inside during the fill
cycle, the problem might be with a faulty water valve (located at
the bottom of the dishwasher, behind the kick panel, on either
side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This
could be caused by a partially closed water shut-off valve (located
under the sink), or a faulty dishwasher water valve (located at the
bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher.
Make sure there is no debris blocking the holes inside each spray
arm.
