Main control board is bad. Drain sequence is a power on test, Main board is not sending signal to open valve or is sensing water is present in the machine when it is not.
The float is located just inside the door either on the left or right hand side, it's a simple float, if it's stuck in the fill position then try a gentle push to release it, and make sure nothing is under the float causing it to stick in the filled position.
The water float switch, located on the inside bottom of the machine, may be stuck in the up(off) position keeping the water valve from functioning. This is a safety device that turns the water valve off when the machine fills in order to keep it from overflowing.
The water inlet solenoid mounted on the inlet valve under the bottom front may also be malfunctioning not allowing the water valve to open and fill the machine. If electricity is present at the solenoid terminals when the machine is in fill cycle, then check the solenoid coil to see if it is open(no continuity). Also, the timer may not be calling for water/ sending voltage to the inlet valve solenoid.
I would start by manually operating the water float valve a few time to see if that helps. You should hear a microswitch click each time the valve stem is moved up or down by the float. If not, check to see if voltage is getting to the float switch and the water inlet valve solenoid.
Most(if not all) machines have a safety cutoff switch which activates when the door is opened. That switch could also be malfunctioning not allowing voltage to the water inlet valve solenoid in fill cycle.
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Water Inlet Valve
Is the valve opening. Since you have a meter set it to the a c voltage range, and check whether you get voltage to solenoid coil where you tested coil resistance. If no voltage reaching check the control board.
For a trial fill water manually to the wash chamber and run the machine. If it runs OK the machine is OK. Otherwise check the float switch/ pressure switch and diagonise further
i would check your incomingwater supply after replacing faulty water inlet valve for faulty solenoid(chances are debris fouled that one. dissconnect at valve ck your pressure, possible after turnig of your water supply your shut-off valevwent bad and not fully opening
Make sure you have water coming to the dishwasher. Next check your dishwasher float. Make sure it is not sticking. If not you could have a problem with your fill valve. Check for voltage at the fill valve if you have 120V then you need a valve the solenoid is defective. Replace it.
There are two ways that dishwashers generally fill. One is a float inside the tub, the second is a tube which fills with water, loops and goes to a pressure switch below the machine. That switch is usually about 1.5 inches in diameter, two wires and a small hose going to it. The float witch is found below the float in the motor area. With the float, sometimes they jam with too much old detergent or food goo. Clean out. Both can have the switch weld closed. Change the switch in either case. Since the unit is not filling with the power off, I'm going to guess the water solenoid is okay.
I don't think that the problem is relates to the leaking water.
Check first the filters on the inlet water line (both sides).
Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
Good luck
