EEC permit error detection and sometime correction but it slower
ok thanks anyone know the max ram it can handle and where i can get a manual for it ?>
If you use a 32bits version of Windows the max is 2GB if it's a 64bits version i don't know (2GB is enough but i think that you can use 4GB) and buffered is an other error detection system(slower too)
thanks dude i will get 4gb its for an xp based 32bit machine you know anywhere i can retrieve the manual for when i put it in the case mainly for front panel connection
i didn't found the manual it's why i give you an evasive answer but give a phot (of headers with not too low resolution)
SOURCE: what is the maximum amount of memory supported by this motherboard?
The 085ch Mobo, which is found in the HP D530 CANNOT support up to 4gb, Only 2 gb
Chipset nVIDIA nForce2 400 + MCP
Processor AMD Socket 462 on board.
Front Side Bus 400/333/266MHz Front Side Bus.
Memory 2 x 184-pin DDR DIMM Sockets.
Supporting unregistered non-ECC DDR 400/333/266/200 DRAM up to 2GB.
SOURCE: i have a packard bell pc with motherboard
usually a bad chip (CPU) or motherboard issue, can you disable it and add an external board? try it if so
