Not familiar with this one, but Korky says they have a replacement flapper that will fit. I haven't seen a topilet that requires tank removal to replace the fill valve.
https://www.amazon.com/Korky-57BP-Fits-Crane-Flapper/dp/B000M2W7WK
SOURCE: My Crane toilet is slowly leaking into the bowl.
Check your over flow pipe in the tank to see if you need to lower the water level amount in the tank. If thats not it, it could be the seal thats under your flapper between the tank and base. Simple fix just alittle time consuming
SOURCE: I have a crane 3-575
That would mean the actual tubing itself has a leak in it or has just worn out. You can replace the whole line there with a new one, I doubt it's the attachment side which is part of your toilet. You are going to want to look into a new line, just head to home depot or lowes (or any hardware store) and get one.
Thanks
Tim
