I just bought this oven second hand. I want an owner's manual
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1
1. Watchdog on board
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven temperature sensor
F3 F4
Open or shorted oven temperature sensor
Replace
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
F7
Function key shorted
Replace touch pad
F8
Analog/Digital converter
F9
Door latch
Check door lock circuit
F10
Function key stuck
Replace touch pad
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
SOURCE: oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
