Looking for a remote shutter release for this camera - or will a wireless remote shutter release work on this camera?
SOURCE: Kodak Z612 won't turn on
while you turn try and turn it on slow twist and pull lens outwards(gently while power on /off) and it will retract back in and power on.Work perfectly after.
Enzomatrixx Da Gr8 One
SOURCE: Horizontal lines running through pictures.....Z612.
I've had sinilar problems with mine. I bought it in November of 2006 and sent it back to Kodak (under warranty) 3x before they finally agreed to replace it (with a refurbed unit). Well, that was in June of 2007 and the problem is now baaaack with the reoplacement camera (same model)... I'm requesting Kodak replace it with another model, but I'm "out of warranty" and they want me to pay them $145 to repair (which they've never been able to fix for me). So I am requesting them to replace with a different model.
SOURCE: how to replace the lcd screen on a kodak z612
open the case of camera using small screw driver
SOURCE: i have a sandisk sdhc card but it wont format on
The Z612 uses SD or MMC cards. It will not accept SDHC cards. You'll need to use cards 2GB and smaller.
SOURCE: How can you format a SD 4gb card for the Kodak
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
