I have this rice cooker (it's very small) and the original instruction booklet:
HOW TO USE
1. Measure rice with measuring cup. One cup of uncooked rice will make about 3 cups of cooked rice.
2. Wash rice 4 or 5 times with fresh water in another bowl. Wash until water becomes relatively clear.
3. Put rice and water into the pan. As a rule, add water to uncooked rice in the following standard proportions.
2 cups rice to 2 - 2 1/2 cups water
3 cups rice to 3 - 3 1/2 cups water
4. Place the pan directly on the internal heating plate, and make sure that the pan is properly located on the heating plate by turning it slightly to the right and left as shown. (see CAUTION) . Before placing the pan in the cooker, wipe off water and moisture from the outside (especially the bottom) of the pan.
5.Put on the lid.
6.Insert the plug end into a wall outlet.
7.Push the switch button to the "ON" position. Make sure the pilot lamp is on. When the rice is done, the switch will turn off automatically, the lamp will go out and a click will be heard.
8.Even after the switch is off, leave the lid on for at least 15 minutes more. During that period, the rice will be properly steamed to a fluffy character by the retained heat.
SOME HELPFUL HINTS
• Always tasty rice
With your National Automatic RICE•O•MAT you can have uniformly cooked rice ... you can even cook rice to your personal taste and preference. Taste and degree cooked depend upon the quality of the rice and the length of time it is soaked before being placed into the cooker. Add more water than specified for softer, more fluffy rice; less water for firmer rice.
• Rice may bubble over ...
If you use too much water or if the cooker is tilted, rice may bubble over. To prevent rice from bubbling over, add water using the cup included (refer to How to use, Item 3.)
HOW TO CLEAN THE COOKER
Do not immerse the body into water or spray water onto it. Wipe it clean with a wet dishcloth soaked in hot water.
SOURCE: national brand rice cooker
I have a NATIONAL brand (Model# SR-EA10N) electronic rice-cooker/warmer that I really like. But the inner pan is worn and I don't know where to find its replacement.
SOURCE: Lost AC cord
The distributor doesn't appear to sell the AC cord online, though I'm sure that if you call them on the phone they would be happy to sell you one. KAMI-NATIONAL DISTRIBUTORS LTD. 13926 West 108 Street Lenexa, Kansas 66215 913-469-5304 Order Toll-Free: 1-800-222-4572 Hope that helps! ;)
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
