Question about Pentax K2 Film Camera
K2 film camera isnot working even after i changed the battery
The camera was not working (would not allow me to take pictures) so i changed the battery and it still wont let me use it...do i have to do somthing to turn it on or will it just work on its own. and if none of these what can i do to try and fix it
    Scholar:
  • 58 Answers
The camera is not dependant on the battery so changing it will not help.
In order to operate the camera you need to wind on to prime the shutter for firing.
The most common fault that jams these cameras is a catch under the bottom cover. A camera repair person will know what to do about that, but it might not be that.
This is closely related to the K1000 so any solution for that camera will apply.
To see how to open the camera up for repair and how to do this properly there is a camera repair site which deal with this and other cameras in detail. alternatively you can contact the author who can offer a very competitive camera repair service for these models.
Posted on Jan 21, 2009
6ya staff
SOURCE:
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
Camera indicator in back that shows how many pictures are left wont shut off and it drains the batteries because of this , it is a canon eos rebel k2 model, thanks for any help
That's entirely correct and normal, but the battery drain caused by the film counter is absolutely insignificant: think how long digital watch batteries last and they have far less power than your camera battery.
If the battery drains rapidly when the camera is not being used then there is something else causing the problem. Make sure that the camera is kept with a lens cap on when stored and not in use and consider removing the battery, although doing so for extended periods means that the camera will lose it's memory.
Jan 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
I have a Canon ESO Rebel K2 camera and my low battery light comes
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Aug 10, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS Rebel S taking bad pictures
Your camera has a faulty shutter or shutter timer.
Given that you can buy a perfectly good Rebel S for anywhere between £1 to £25 on Ebay it's not economical to repair it.
Jul 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Nov 18, 2008 | Canon EOS Rebel K2 with 28-90 lens 35mm...
White balence
The EOS Rebel K2 is a film camera. White balance settings on digital cameras are an electronic 'adjustment' to the image sensor. In film cameras, the film is the image sensor. So white balance is dependent partially on the film you're using, but more often on the filters you add to the lens to correct for various lighting conditions and light sources.
Jun 13, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Pictures did not take
Check for the settings of the camera .Open the back door of the camera now press the button seeing through back, if the shutter opens up and closes everything is correct.
check for the film.
Apr 01, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Like i said before i do not know how to advance the camera
Here is Canon's spec page for your camera. CanonUSA
The camera is a preloader. It rolls all of the film out of the canister and winds it back as you take pictures. Read the film transport section. You have installed a battery in the camera right?
Mar 15, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Open Questions:
Pentax K2 Film Camera Logo
172 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
