I used it for three days n when I took out the sim card for some reason and wen I put it back, I started to have this problems
Hi, Your Blackberry 8830 world edition has been network restricted. That is why it says " insert sim " . you can remove the network restriction from your Blackberry 8830 world edition by entering the unique unlock code. You can get the unique unlock code for your Blackberry 8830 World Edition from www.SimpleUnlocking.Com at affordable cost with free unlocking instructions. all the best mate.
SOURCE: can i use rim sim card & gsm sim card in only one phone...
you can cdma sim use only in rim programmed mobilephones,can not use all gsm mobilephones
SOURCE: Sim card not readable
maybe your phone is not open line to other sim card network..
thank you
SOURCE: Can we change use a GSM SIM cards in a CDMA
No.
Not at all. CDMAs are different platform of handset.
Cheers.
SOURCE: cdma sim not working in A918 chinese phone
Hi, In GSM & CDMA seeting option you have to do the right selection. For e.g. In Slot 2, you have to select CDMA. & in Slot 1 GSM. Then it will work. Hariom
Testimonial: "slot Ok . It shows a message of unable to connect while calling and no incoming calls"
SOURCE: conversion of CDMA SIM into GSM SIM without change of number
it is not posssble to convert a cdma sim in to gsmj sim.For the gsm phone,you will buy a new gsm sim connection.
Testimonial: "Hi, thanks for the assistance. Can you recommend me some good cdma handsets."
