Won't disperse soap
Hello - Are you referring to the spray arms will not rotate? If so, do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies. I will suggest verifying that there is enough water pressure coming into the unit. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board or wiring connections to the dispenser, I would suggest contacting a professional technician to diagnose the unit accurately.
SOURCE: Frigidaire Dishwasher - Spray Arm Not Working
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
This all may be due to an impeller problem in the pump housing under the lower washarm. If the impeller is damaged/bad the pump will not circulate water through the wash system correctly. On most Frigidaire dishwashers the lower washarm and top pump cover can be removed fairly easily to check it out.
Go here for: Frigidaire-Dishwasher-Parts
RepairClinic.com
appliance parts, help & more
SOURCE: Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
SOURCE: I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
SOURCE: After removing the bottom assembly from my
The ball goes under item 10 this picture:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=381580&pkw_=basket&model_id=5120395&NewWindow=1
You can enlarge the picture once opened. The Expert Gene Strote was correct. I just like this picture better because you can instantly expand it with explorer.
Manual Number 5995477345.pdf is a service manual not for your unit but will show you the sump and were the ball goes.
http://appliancedigest.com/index.php?/files/file/147-frigidaire-fully-integrated-direct-feed-model-dishwashers-5995477345-service-manual/ (registration required)
A service manual that will show you the sump area and the ball.
Thanks for choosing FixYa, and myself.
Kelly
Hello Eric, thank you for your post!
I understand that the dispenser on your Frigidaire dishwasher opens but the soap is not dispensing into your dishwasher. How old is your dishwasher soap? If it is around a year old you may need to discard it and use a new soap. Also check to make sure when you stack dishes that they are not obstructing the arms from reaching the dispenser. Make sure your spray arms are clear of any debris that could block the distribution of water inside of your dishwasher. You may need to connect with a professional technician for proper repairs if these steps do not correct your issues. I hope this information is helpful to you. -Matt
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
