Step by step instructions
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers,
Chris
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
SOURCE: Where can I buy print head for Kodak ESP 9
Kodak says that they will not let the print heads be sold at retail... I don't know why, the ESP series printers seem to all need their heads replaced regularly.
SOURCE: Kodak ESP-7 won't print Word Art
This isn't a solution, but a workaround...
If you create your word art, you can right-click on it, and save it as a graphic. Reimport the graphic into Publisher and it should print (at least it did on mine).
SOURCE: how to clean print heads on kodak esp-3
Press and hold Cancel and Copy button simultaneously until the
On/Off light flashes green. you will see a flashing green on your printer it means its now cleaning the printhead
You can also clean a printhead using computer., first you need to launch the Home center software On your computer and on the uppr right corner of the windows of the software click help icon(?) then go to maintenance and under maintenance you should see the clean printhead. GudlucK!
Testimonial: "Good advice, thanks - had already tried this tho'. I ended up phoning Kodak helpline and am having a new print head sent to me FOC."
