American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga Logo
Ann Crawford Posted on Nov 20, 2012
Although we have really tightened the wingnuts on the bolts which attach the toilet seat to the unit, there is still a lot of side-to-side movement int he toilet seat. We have an identical toilet bought at the same time which has the identical problem. Any suggestions to improve this situation? Is it a design flaw in the toilet seat assembly? Has anyone else expeienced this problem?
4 Related Answers
shepnaz400ex
Tony Sheppard
  • 46 Answers
  • Posted on Sep 04, 2009
SOURCE: How much draw down (tightening) do use to attach
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Harderfaster
Jack McMahon
  • 34 Answers
  • Posted on Jun 12, 2010
SOURCE: How can I remove a stuck plastic bolt on a toilet
hacksaw
Anonymous
  • 40 Answers
  • Posted on May 18, 2011
SOURCE: Hi, I want to replace
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile. put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug. You will need; Electric percussion drill or descent battery drill. 7 ml tile drill bit 2 x rawl plug 7ml 2 x screw masking tape is handy hope this helps, Alex
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Jun 29, 2011
SOURCE: I have a problem with
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
1helpful
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
1helpful
Toilet seat slips
You will need to tighten the bolts holding the seat to the bowl. This video well help although the seat may not be the same as yours.
http://vodpod.com/watch/793915-tighten-toilet-seat-bolts
The toilet seat is very loose and I can't figure out how to tighten it. Please help! Its about to come off completely Thanks
Usually there are plastic caps that snap down over the bolt head.
Shut toilet lid and get down close with a flashlight.
Seat attaches in two places.
Reach underneath and you can feel two bolts with nuts.
You don't need to see them, just feel with your hand.
The bolt head is covered with a plastic cover.
The cover is added for aesthetic purpose only.
Use small screwdriver or fingernail file or nail or scissors to pry up the cover and reveal bolt head.
Use bigger screwdriver to tighten bolts.
You may have to keep one hand on underside to hold nut while turning bolt clockwise.
Another trick is use hand to push bolt all the way up, and then finger tighten bolt most of the way, and use screwdriver for last few turns.
Tighten bolts good and tight, but don't overdo it.
Bolts will come loose again and you can tighten more later.
How much draw down (tightening) do use to attach the water tank to the toilet bowl on a American Standard Flowise Cadet 3 toilet? Does the tank need to meet the bowl?
1helpful
Toilet seat connectors mounted on toilet is loose
There should be a way to tighten the bolts without going that far Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in palstic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
If the bolts appear to be cast as a part of the hinge assembly, you should be able to reach around the seat to the back side (no pun intended) of the toilet, and tighten with a wrench.
I sometimes use a 'mirror trick' to get a better idea of what's back there. Just use a small mirror and hold it to where you can see the bolt and not on the back.
Hope this gets you going (oops, another unintentional pun).
Best regards, --W/D-- please feel free to rate this solution..thanx!
Aug 01, 2009 • Home
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
