Hi, I have a simmens 8 kg front load washing machine. 17 - 49. It says "child lock active, mix needs to be set." I know there is something with delicates but it is not working. Any one have any tips or know what to do. Thanks!!
SOURCE: child lock
look for a button with possibly a lock emblem beside it ..usually has to be held down 3-5 sec to unlock
SOURCE: Hi How do you remove the child lock on a Bosch
Hi
Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Thanks for contacting fixya.com
SOURCE: need to disable child lock
If you didnt lock the unit yourself - the ECU is failed and needs replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: I am house sitting &
Go to the link below. On page 23 will tell you how to turn off the child lock.
http://laundry.manualsonline.com/mdownloads/338a7e94-97f6-4c32-a1ad-ff603a7f9933.pdf
Good Luck and please rate 4 thumbs up and please leave a testimonial
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
