Panasonic Lumix DMC-FZ5 Digital Camera Logo
alastair Macdonald Posted on Jun 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black LCD screen , new photos black.
Great camera until today when LCD screen (and Diopter) won't give picture preview. LCD works (previous shots able to be brought up on screen) but any new shots are appearing on photo record as black. Cannot locate anything which would reset back to original factiory settings. Prob seemed to be initited when 16 yr old stepdaughter 'borrowed' camera. Help please from anyone and you can join me on a NZ photo safari.
  • alastair Macdonald Jun 06, 2007
    Thanks Jackboy, Camera away for repair now and my thoughts are the same as yours re connector. Initially thought there may have been the possibility of a reset to factory specs - hence ?'s.Best Redmac
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jun 03, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027895
Points
5636
I assume you mean the viewfinder screen. This has become inoperative because very likely it has been given a knock, and [at the very least] a connector has come adrift. But it could be worse. It will be a repair shop job I fear But do get on to Panasonic Technical Support just in case I have misdiagnosed.
5helpful
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
2answers
Got a used Ricoh CX1 from ebay today. Everything is good except when I preview the pictures I had taken, if I preview at 1X, (normal mode), I can some black shadow like lighting happening inside my...
Looks like the LCD screen in damaged... If you can tolerate the "blob" and it doesn't show up in your images when they're downloaded, then it's not an issue, but if you want to change the LCD, go back to ebay and type in your camera model and "LCD". There are a few camera dismantlers that sell on ebay and you'll find a good deal.
No preview image. Black screen LCD
The problem is not with the LCD or the camera - You have got it set to ecomony / power save mode. Fixable through camera settings.
Preview screen half white, with black blob!
I think ribbon connector of LCD is misaligned in your camera.
If you are comfortable with it, please apart camera and readjust ribbon connector at main board.
2answers
New Camera, no picture on screen
This is normal for this camera. Think about it. The CMOS chip can't see through the mirror. After the shot is taken the electronic shutter exposes the CMOS chip and makes an image just like exposing film on a film type camera. Once you get used to it you may like it better. In outdoor or bright light situations it's difficult to view the LCD screen to frame the shot anyway.
Kodak C643 Screen black
One way out of the glare is to use the optical viewfinder (if your camera has one) to preview your image instead of the LCD. Another possibility is to buy a camera that has a backlit LCD.
1helpful
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
2helpful
LCD screen won't show preview except in C mode
Well, after a little more googling, I'm embarrassed to say I've found the solution. I must have somehow pressed the display button which turned the preview display off. I tried pressing all of the buttons before I made my previous post, but apparently i didn't press it. :(
2helpful
2answers
Black screen
whats up with blackscreen?
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
