so the engine runs or just cranks with the starter? will the gear lever move? with the cover off the engine can you see the linkage moving? i cant help if i dont have details
remove spark plugs and you should be able to rotate the flywheel easy ! then try starter to spin over , if not then remove starter and check the brushes inside etc ! check solinoide ok ! check wires ok !
Check- Do You Have Spark At The Spark Plugs?If Not Then It Could Be Stator Or CDI Unit Or Trigger, If Yes Good! Have Carburetor ('s)Got Fuel In Them? ,If Not Clean Carb's. If Both Are Correct It Should At Least Fire Good Luck
