Brother Limited Edition LS2250PRW Project Runway Sewing Machine Refurbished LS2250PRW Logo
savithri gogineni Posted on Nov 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Straight stitch is very loose and unable to fix it. tried every thing i think of
Debbi's Sewing Machine Repair
Level 3:
  • Brother Master 7,365 Answers
  • Posted on Nov 20, 2012
Brother Master
Level 3:
Answers
7365
Questions
Helped
1744210
Points
19451
Try adjusting the top thread tension and see if that help the stitch
here is a free quik start guide, just click on the link
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_LS2250PRW_EN_2732.PDF
and here is a free manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS2250PRW_ENES_2733.PDF
Huskystar 207 Sewing Machine stuck on zig zag stitch
If your Huskystar 207 sewing machine is stuck on zigzag stitch even when you have selected a straight stitch pattern, there are a few things you can try to troubleshoot the issue:
  1. Check the needle position: Make sure that the needle is in the center position. If it is not, you may need to adjust it using the machine's settings.
  2. Check the stitch length and width: Make sure that the stitch length and width are set to the appropriate settings for a straight stitch. Refer to your manual for the correct settings.
  3. Check the tension: If the tension is too loose or too tight, it can cause the machine to sew a zigzag stitch instead of a straight stitch. Make sure the tension is set correctly for the fabric you are working with.
  4. Clean the machine: Sometimes, a buildup of dust and lint can cause the machine to malfunction. Try cleaning the machine, particularly the bobbin case and feed dogs, to see if this resolves the issue.
If none of these steps resolve the issue, you may need to take your machine to a professional for repair.
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
When I embroider with my Pfaff Creative 2 the top tension pulls bobbin thread up too much. I changed toe tension on top but it still does the same thing. How can this be fixed?
Suggest you do rethreading ,then test the stitches on straight stitch. If top stitches is loose you have to reduce the upper thread tension, if the bottom stitches is loose you have to increase the upper thread tension. Adjust accordingly till you can get a perfect straight stitch. If okay then you can continue your embroidery work.
1helpful
2answers
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
1helpful
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 • Juki TL-98Q
4helpful
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
