I downloaded the dell drivers for my laptop after re-loading windows 7, it ran fairly quickly, everything seems fine until I shut it down. It won't restart again, I've gone through this a few times with the same results.
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
SOURCE: Dell Latitude D610 dvd player won't work
Try a CD ROM lens cleaner. If it fails then I suggest you buy a new one. It is easy to change it: there is a release switch at the bottom with a screw. Open it and remove the old one. Slide the new one into its place.
SOURCE: DOWNLOAD OF DELL LATITUDE D610 SOUND DRIVERS
You can download the DELL D610 driver from the link below. You can also download all other drivers and utilities from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
SOURCE: My Dell Lattitude laptop shut down and won't restart.
possibly faulty battery. Try replacing it for a new one.
SOURCE: my dell d610 laptop is giving me an error code
The error code indicates hard drive failure.
You can take out the hard drive and connect it to a hard drive enclosure. Then connect the enclosure to a working computer to take a backup of your important data.
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
