Here's the link for you to download, check if it matches yours. If not, u might need to clarify the model from the wireless card itself.
http://www-307.ibm.com/pc/support/site.wss/product.do?doccategoryind=50655&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&brandind=10&familyind=168386&machineind=0&modelind=0&partnumberind=0&subcategoryind=0&operatingsystemind=49979&validate=true
You rrate for my solution is much appreciated. thanks
SOURCE: Thinkpad R51 wireless driver
On the bottom of most laptops, you can gain access to the WiFi card. If you can do this on yours, they usually have the name of the card on a label on the card. This will help you identify the card maker and you should be able to get the driver from IBM or "google" a driver based on that info. If that info is not clear, there should be an FCC ID # somewhere on the card. You can then go to www.driversguide.com and use the FCC ID to see if a driver is listed.
Hope this helps
My laptop is IBM ThinkPad R51, Now i have problem. After i installed my window XP operating system, i don't get wireless driver. Please help me, where i get this driver.
Regards
Mahmuduzzaman
Mobile no: +88-01819008152
are you looking for the driver for the wireless card installed in the notebook ?
did you install this card .. or did you purchase the notebook with it installed?
