I have installed the DP-301U. When printing from my laptop, I can see the documents in the print server (by connecting directly to the print server and clicking system > network). However, the documents are not being released to the printer. I amn using a HP 1020 (not on the compatability list). Have I missed a step? If not a compatible printer, is there any work-around, like installing a similar printer, or should I just return the unit? Thanks in advance. Digger
Hi... I installed the driver hp laserjet 1022n and work with dp301u (d-link).
Thanks. My laptop can see the print server, as I see all my documents in the queue. (and I can also successfully ping the print server). It appears the HP LaserJet 1020 is just not supported... Looks like a return is in my future. Thanks. Digger
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
