My ps3 says "connect controller using usb cord and press PS button" but the only controller i have is a corded one because my other one was chewed up. So the controller i have you have to plug into the usb ports. So when i do plug it in and press the PS button nothing happens. AAnd im really mad and want to play my game.
I have a battery packed controller that has no USB cable option. So how can I do any of these answers you guys are recommend if I have no usb slot on my controller
Hello. guys i have a big problem with my usb. First.Off my left usb port's insert (where you plug in usb,charging cable,etc) is broken and when ilook in through the usb port it looks different then the other one but i cant put my finger on it. Anybody got any suggestions?
U need a sony ps3 controller
SOURCE: PS3 Controller will only work when plugged into the USB
i had same problem turn off your system with controller plugged in to usb unplug controller remove the power cable for a couple of mins reconnect and use controller PS button to turn system on and it should be back to normal. it worked for me
SOURCE: CONTROLLER PROBLEM
Try resetting your Controller. Using a paper clip, there is a small reset button on the underside of the SIXAXIS. Press it.
While your PS3 is still on, press the PS button on the controller.
SOURCE: PS3 controller disconnects while playing games or watching dvd's
Check the controller settings under,
SETTINGS, Powe Save Settings, Controller Auto-Off
If that doesn't work try performing a hard reset on the controller like this:
Flip the controller over, and press the reset button. It's to the right of the middle-top screw .
You'll need something like a paperclip, toothpick, or something similar
to push the button. Once you've reset your controller, connect it to
your PS3 with a handy USB cable, and press the PS button (just like you
did when you first got the controller). Now, it is paired again, and
you should be OK.
Let me know what happens.
SOURCE: My controller will not connect on my ps3.
Sounds like the controller knows it belongs to the other PS3. It has already "paired" with one console, so that's why you're having a hard time trying to get it to pair with console #2, comprende?
Make sure console #1 is a "hard off", like switched in the back. Now flip your controller over & put a pencil or pen tip in the reset hole. ( Just to the right of the center screw hole.) NOW connect said controller with the USB to console #2. Hold the PS button for two seconds. All 4 lights will flash 5 times, then the 1 light should stay on, Boo-ya! You're PAIRED!
SOURCE: Ps3 times out "invalid format" using hdmi cable
its the game in the game there is a trade mark thing and it thinks u are copying so it does any thing to stop u by doing a error382
or
its your cords and your useing a really cheap brand the does not sut your tv and it is does not sut your ps3 so it will cut out and make errors
