Plug in turn on main power switch and standby power light flashes. Then press power button and power light will burn solid for a few seconds then goes to flashing again. No other sign of life. Can you help? What is a normal symptom if the main lamp fails to light?
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
