Probably a sensor is getting wet, triggering the ECU with the wrong information, therefor turning on some of the dashboard lights on.
Sometimes, a little bit of grease on the sensor keep the sensor from getting wet. If there is no light on in the dashboard when its dry, then that's your problem.
First things first.... Is your car low on gas( gas light). Second look for a traction control shut off switch in your owners manual , find it in the car and press the button, you may have hit the button and not know it. The service engine soon light needs to be scanned and cleared with the code or codes documented.
the trac light is the traction control, the abs light means the antilock brake system is not functioning properly. the trac control is no issue. the abs will not cause the brakes to fail but they will lock instead of pulsing.
when ever the check engine light is turned on for any reason the vsc and trac light also comes on to let you know they are not working, whenever the engine light is on the other systems can not operate if the engine is not working correctly, so its programed to shut down the trac and vsc when the engine light is on. the catalyst system means the catalic converter is no longer cleaning the exhasut to specs, this is caused by a weak bad converter or bad o2 sensors giving false readings you will need to have the sensors checked to see if they are the problem or the converter is the problem good luck.
There is a button (on the shifter console in my alero) that turns oof and on the "trac". I'm not sure of it's purpose but if I push that button, the "Trac Off" light comes on.
trac on trac off (traction control system)
tyre preasure light on mean that these sensors
may have been damaged or placed out of calibration during your brake repair
are they still on ?
can you turn off your trac light ?
usaly an ABS light and engine light come on when a wheel speed sensor is falty. you can fiz this your self. message me if you want to do this your self.
did you get anyone to check the codes?
the trac off light will come on if the ignition module goes the module sits on top of the engine it has silver fins and is held in with 3 torx screws. it sells for about $100 so you might want to have someone diagnose this hope this helps
