Acer Emachines D525 & D725 Laptop Keyboard Logo
jony mohon nag Posted on Nov 17, 2012
Bios password clear
I want to do bios password clear because i have forgotten it. How can I do this?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
457
Points
Just open the case and remove the BIOS Battery...
and then it has been removed....^_^
How do i clear all forgotten passwords ,including dell security manager authentication password (bios)
with the power off and unplugged disconnect the hard drive for the computer. now reboot and go into the bios and try to clear the password. If it is stall asking for a password with the hard drive disconnected then clear the bios password by the jumper on the motherboard. for the cmos reset. If that does not clear it. remove the button battery and wait 5 minutes and reinsert battery and try again.
you also may have a hdd password if you do then re-post for directions on how to remove hdd passwords. Good Luck.
Bios password
I think the only way past a forgotten BIOS password is a CMOS clear, which would involve dismantling the laptop to get to the motherboard and find a clear CMOS jumper, or pull the CMOS battery, which can be a risky maneuvre.
Fujitsu siemens s7110 laptop bios password
if youve forgotten the bios password you will need to remove the main battery, the power cord and disconnect the cmos battery to clear the bios password
its better to have a tech do this for you
2helpful
2answers
Cant remeber my bios password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
2answers
Toshiba Satalite A215 Laptop Bios Password
remove battery.....wait for 3 minutes....put it back and turn on...the bios wii get reset.....
if it still didnt got reset, then you need to remove cmos battery in the board by removing the back cover....
13helpful
4answers
ACER ASPIRE 4730Z. How do I clear the CMOS (password)?
Below is the steps for clearing the password. Below that is the link for the manual, the picture of the jumper tabs is on pg. 153, good luck
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
http://tim.id.au/laptops/acer/aspire%204730z%204730zg%204330.pdf
1helpful
3answers
Bios password cant boot password protected
3answers
Bios password,
If you have a BIOS password and cannot remember what it is, download this program, run it and reboot your machine. Should remove the password for you. http://www.cgsecurity.org/wiki/CmosPwd
1helpful
2answers
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
