What componet would I have to add to camera so I could take pictures without touching the camera controls
SOURCE: Kodak Easy Share M753
the answer can be found on pages 39 & 40 of the User's Guide for the Kodak EasyShare M753/M853/MD853 zoom digital camera
SOURCE: pictures are blurry
The auto-focus mechanism is defective. Take it back to the vendor and exchange it for another one.
Hope this helps,
Chris (ziraffa)
SOURCE: how many pictures can a kodek easy share m1063
In your menu you will have a choice of "resolutions"(picture size) such as 9.0 mp,8.0 mp,6mp.8mp,5mp,3.1mp,2.2mp,2,1mp,1.2mp. The small the size(and poorer quality) that you choose, the more pictures you will be able to take. Your camera prob has internal memory of 32 mb and when you have selected your picture size it should show on the screen how many pictures you are able to take. Mine for instance will take 5 photos at 9 mp but 16 at 3.1. It really is worth having a spare memory card at all times to enjoy your camera fully.A 2 gig card gives over 1000 photos at 9mp.
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
SOURCE: Kodak Easy Share CD1013 pictures won't download on Vista
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
