Cars & Trucks Logo
A
Anonymous Posted on Nov 17, 2012
How to reset sat nav in jaguar xf 2008 - Cars & Trucks
Adam Wasylko
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 09, 2016
Adam Wasylko
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
953
Points
The latest 2016 sat nav update for jaguar xf
http://www.latestsatnav.co.uk/the-latest-2016-sat-nav-disc-update-for-jaguar-xf-and-xk--navigation-map-dvd-61-p.asp
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 20, 2009
SOURCE: Sat nav
sat nav,??ive driven for years without it ,open window and ask or follow a bus ,thats my favourite
Anonymous
  • 375 Answers
  • Posted on May 14, 2008
SOURCE: XF jaguar
No price anouncement as of yet.
One of the guys on the sales frontlines thread is a Jag salesman just keep an eye out there.
maaaartin
  • 561 Answers
  • Posted on Nov 12, 2009
SOURCE: i have just bought an x type jaguar. The sat nav
Ensure the map data dvd that you have for the car covers the uk. it might only cover mainland europe is should state GB on the packaging or on the disk itself.
alteratively in the set up the previous owner may have removed uk maping or uk post codes from the system and they may needed to be reloaded.
if your system an navteq one prior to 2003? it is known that the mapping from that period did not support uk post codes i assume buying a new mapping software will resolve this issue. I would recommend checking with jaguar in case any system software upgrade is also needed to read later mapping data versions.
Testimonial: "Excellent prompt reply. Thank you very much."
Anonymous
  • 501 Answers
  • Posted on Nov 28, 2010
SOURCE: how do you put the dvd in the jaguar sat nav
I have an 03 s type, the navigation dvd reader is in the trunk on the driver's side with a small compartment you pull down and push the only button and the tray opens and closes. With a newer dvd you will need to go back into the navigation settings and update some basic info.
raygin
Raygin
  • 322 Answers
  • Posted on Feb 16, 2011
SOURCE: how do i install a
I assume you have a jaguar sat-nav system installed. To update you can buy an updated disc which is compatible to your car system and which will contain all new information/routes etc. simply load this into you unit and follow any instructions. Hope this helps - good luck!
2011 Jaguar XF diesel saloon 2.2d. I need fuse box diagram for it please.
Question edited for clarity and toss in some CAPS.
Question moved to model category.
All here and also your Owner Manual
fuses JAGUAR XF 2011 1.G Owners Manual (225 Pages)
Car Manuals Online https://www.carmanualsonline.info > jaguar-xf-2011-1...
View, print and download for free: fuses - JAGUAR XF 2011 1.G Owners Manual, 225 Pages, PDF Size: 7.32 MB. Search in JAGUAR XF 2011 1.G Owners Manual online ...
Jaguar XF Premium 2011 Engine Fuse Box/Block Circuit ...
CarFuseBox https://www.carfusebox.com > jaguar-xf-premium-20...
Sep 3, 2022 - Jaguar XF Premium 2011 Engine Fuse Box/Block Circuit Breaker Diagram ; 1, 10A, Security and Locking Control Module (Reversing Lamps, Rear Fog ...
Missing: diesel ‎' Must include: diesel
Different Fuse Boxes 2011 XF
Jaguar Forums https://www.jaguarforums.com > xf-xfr-x250-44 > dif...
Apr 16, 2017 - Different Fuse Boxes 2011 XF ... While checking fuses for the EPB (Park Brake) I found that the layouts were very different to the list in the owner's manual.
2013 XF Passenger compartment fuse box diagram
May 23, 2018
Engine compartment fuse box diagram xf 2013 - Jaguar Forums
May 23, 2018
2011 XF Fuse Box - Jaguar Forums
May 28, 2013
XF 2010 Fuse Box (Bonnet) picture - Jaguar Forums
May 17, 2018
More results from www.jaguarforums.com
How do you reboot Jaguar XF 2008 sat nav/radio unit please.
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
Where is fuse for multi media screen in the car
if the touch screen is blank it is normally caused by problem with the d2b fibre optic network or no wake up signal being received by the module or one of the other modules on the network, try a battery reset ie remove the neg battery lead and leave off for 5 or 10 mins reconnect and retest, if that fails you need to take it to someone with the correct test equipment to check out the system, hope this helps, i worked on these cars since launch and recently retired, not easy to repair without the correct knowledge and test gear, depending on age it may need some modules reprogramming to correct this.
1helpful
Sat nav on jag xf. the direction arrow on sat nav always points in compass direction of travel ie if going south then arrow points down over. is it possible to have arrow always pointing up like tom tom
the touch screen on the car should allow you to change the compass setting...I cant remmeber if yours has this but see if you can touch the compass on the screen display to make the direction allow of the car be in accordance with the cars real movement or north as you wish..Keep me posted
2helpful
How do i install a sat/nav update on a jaguar xkr
2helpful
Any ideas how to reset the service light on a 2009 xf please?
have your mechanic remove the combination meter ,there is a reset switch.
Sat nav
1helpful
2answers
XF jaguar
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
