My car was written off . I managed to save the Blaupunkt Calgery Radio and the Changer but could not remove the connecting lead. Bluespot UIK say the Changer has long been discontinued and cannot supply parts. The lead had a box style connector each end. Can someone help please. Tony
SOURCE: Blaupunkt MP74 compatible CD Changers
Specifications
Amplifier
Output power: 4 x 18 watts sine
at 14.4 V and 1%
distortion factor at
4 ohms.
4 x 26 watts sine
in accordance
with DIN 45324
at 14.4 V at 4
ohms.
4 x 50 watts max.
power
Tuner
Wavebands:
FM : 87.5 - 108 MHz
MW : 531 – 1 602 kHz
LW : 153 – 279 kHz
FM frequency response:
20 - 16,000 Hz
CD
Frequency response:
15 - 20,000 Hz
Pre-amp out
4 channels: 4 V / < 1 kω
AUX input
Input sensitivity: 1.2 V / 10 kω
Above are specs for the LA mp74 digiceiver
This is where I found the pdf information for cdc ao71 changer, only problem is it is in other languages.
http://fe0wap79.bosch.de/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/EUR/BeAT_ServiceDocuments-Start;sid=xMwY5KjfON3gIuDbMbhKGKdU-8dWMZg3sZ0=?Language=FR&search_query_name=cdcao71&SellerId=CM_DE
I will keep looking.
SOURCE: Blaupunkt IDC-A09 5 Disc Changer
Hi try unpluging both the cd and the head unit from power for 30 mkins or more. this should reset the system. plug the head unit in 1st then the cd.
regards
Mark
www.blueice-electronics.co.uk
SOURCE: Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
SOURCE: Clarion 12 Disc CD Changer Model # CDC 1255z What
out of focus.
if all of your discs have the same error code 6, it is optical lens problem. have it checked to the nearest service center.
