Phillips 42FPL7662D/05. I do not know why the tv has stopped displaying a picture. The power supply is okay. I have taken the back off, there does not seem to be any problems with any soldering. If you know of any solutions. Please contact asap. Thank you.
    Genius:
  • Televison & ... Master
  • 2,432 Answers
If still the sound is working but with out any picture the cause would be a screen back light failure or malfunction in the t-con board. if the totally black screen it was a failure in the back light, you will need to remove the back cover to access this part. it was located at the upper and lower portion of the panel display covered with metal shield.now if the display is only a white screen you can see it in dark room, then the cause will be a failure in the t-con board. the t-con board was mounted underneath covered with metal shield.before you come up with trouble shooting the t-con board tried first with re seat the connectors which have loose contact.hope this can help good luck.
Posted on Nov 18, 2012
6ya staff
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: Protron PLTV-32CM LCD no picture
This TV set is still under the warranty and it seems proton has no local service available to you. I know its to late to tell you this but anytime you purchase a set, ask first and see if there is a service local to you. Ok enough of that noise.. I would go back to the store where it was purchaced and ask them if they know of any local shops that handle the warranty repairs.. If you want to pay for the repair, and that will most likly be alot for a flat panel set, You will have to call back proton and ask about the shipping cost and whos responsible for that.
Posted on Sep 30, 2006
Anonymous
SOURCE: TV MAXIM 11-54
I can supply a repair kit for that for £40.00
Plus delivery
Or a new PSU for £98.00
Plus delivery
www.FixMyPlasma.co.uk
Posted on Nov 29, 2007
Anonymous
SOURCE: TV-3940-01 upgrade kit ordered. What about power supplies?
i have same problem with my plasma, haier was absolutly no help. could you email me tech manual and instructions for upgrade kit. thanks
Posted on May 16, 2008
Anonymous
  • 8 Answers
SOURCE: Haier 37" LCD TV...need a power supply
There is a Haier Authorized Servicer in NYC who repairs the panels. Give them a call . Website is www.asnyonline.com
Posted on Jun 30, 2008
Anonymous
SOURCE: my 42 inch plasma wont turn back on after power cut?
Go buy a CRT television for $200 and chunk that HD TV. All of them are made in China with the same poor quality. Why seemingly smart Americans would pay good money for such junk is beyond me.  The LCDs are a cash cow for the monitor and TV industry as they are well aware the inverter boards will fail within 3 years time.  The old CRT tvs will work for the next 15 - 20 years without failure. Get you a good ole 36 in sony black stripe tube and kiss the LCD crowd good by.
Posted on Nov 28, 2008
My RCA 46 LCD has no picture or sound but the blue lights on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 02, 2015 | RCA Televison & Video
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Phillips lcd tv model 42pfl7662d/05 set turns on have sound but no picture
Hi.
The problem is the inverter, the psu, or the main board. Repair is done checking power to the inverter.
Please let me know if you need more info on the problem.
Regards.
Ginko.
Mar 08, 2011 | Philips Televison & Video
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips 427220a
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Mar 08, 2008 | Philips 42PF7220A 42 in. Plasma Television
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Plasma P50H401 tv will not display picture
I know this might sound stupid but try changing the channel or changing the aux / cable / tv button... I  had to put my phillips 50" in the shop for the same problem ..but I had it for 3 yrs .they said it was the power supply and will cost 1k to get the power back and may cost evne more if one of the boards went out (video i guess?) so make sure u get the extended warentee u will need it .Its only a matter of time ... good luck quickdrj
Oct 12, 2007 | Hitachi P50H401 50 in. Plasma HDTV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
