CD function in 5 disc stereo constantly flashing "CHANGE"
"Almost new" condition stereo. Has one disc in 5 changer drawer. Now will not operate at all. Constantly flashing "CHANGE." Will not play, open/close drawer, no "DEMO" function, no "change/check cd" functions. Played OK when first cd put in, then when attemps were made to add more discs, nothing is operating. H E L P !!!!!!!!!!! Cassette/Tuner functions 100% OK
    Top Expert:
  • Audio Player... Master
  • 55,370 Answers
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Posted on Nov 20, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
Lashawn Robinson
  • 1153 Answers
SOURCE: Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Posted on Oct 08, 2007
Paul
  • 224 Answers
SOURCE: CDs won't play RCA RS2651
I think the laser is mis-aligned or the laser unit needs replacing. If you are able to check this for yourself otherwise find a competant technician. Hope this helps.
Posted on Oct 06, 2008
Anonymous
SOURCE: doesn't recornize Cd's and won't play cds
I have a AWM-2700U (3 disc changer) that was doing the same thing. I removed the cover and found that the laser lens for the CD player had come out of it "slot". I cleaned it with alcohol and a cotton swab and replaced it in the slot and it has worked for the past 3 months since. Hope it works for you.
Posted on Dec 07, 2008
Anonymous
SOURCE: error 0306
hi there, I suggest you should open the top cover of the cd tray, have a look inside do a little cleaning also when you screw back in, make sure you screw in properly( you propaply find that someone had open it up before and screw it back in really tight so the cd trey jam inside, or another alternative something might of broken inside and tha can stop the cd trey from opening. it happen to me before and thats how i fix it. good luck hope it works.. cheers
Posted on Jan 03, 2009
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
How can I get my RCA 5 disc CD changer stereo to work right?
I have an RCA 5 Disc Changer, purchased at Target. The first one had a prolific issue of skipping on discs. It would play part of song on the first disc then suddenly change to the next disc. However, it did not ALWAYS do this, just sometimes, seemingly at random. Then one day, it would suddenly work just fine on all 5 discs. Eventually it simply would not play an entire song at all, so I took it back (within the time of the warranty). They had 1 of the same left on the back shelves so was able to get that one. This one started doing the exact same thing within the month. Now, it will not READ discs. It will simply read, 'Read"..and then when it comes up showing the disc number it has all zeros. I tried skipping to the next disc and then the next, and suddenly it read. That was fine for two days, then it would not even do that. I tried using compressed air inside all of the open disc drawer, and on all the discs but to no avail. Just now I tried tilting the entire unit Back at about a 30 degree angle and while in that position hit the 'disc change' button on the remote and suddenly it read. How long will this work? Have no idea. Very irritating - and it's hard to find this kind of player anymore, apart from a Component System which is a whole new playing field. Amazingly , I had bought my first changer, a 6 CD changer, cheap one at wal mart long ago and it lasted me about 10 years and never had a problem. It was a no-name brand too, I would expect better from RCA but alas, tis not the case.
Jun 05, 2014 | RCA Audio Players & Recorders
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
Hello. My Sony CD changer "drawer" comes out and then immediately goes back in. It does this about 85% of the time, not always. This is a single CD changer that I like a lot. Thanks. AK
Dear Sir., you must change the "motor driving belt" because the mechanical system is not completing the function "sometimes drawer don't comes 100% out " that's why is going back to close!,
if you could change the "motor driving belt" that is the rubber that drives the motor for the mechanical part that open and close the drawer, your problem should be solved.
thanks.
Jan 30, 2011 | Sony Audio Players & Recorders
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
I need the code for my car stereo ser no-
Try code 1262
If this does not work , please quote the MAKE of CAR.
(I`ve assumed that it is fitted into a Fiat)
Nov 02, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
ADCOM GCD700 5 disc CD player
Are you sure the fuses located on a PCB below the opened drawer are all OK? Otherwise you likely have a mechanical issues and I suggest you contact an Authorized Adcom Service Center. For further information visit www.adcom.com and contact Adcom. Affiliated Electronics in Hillsborough, NJ, may be your best bet as they have salvage Adcom parts.
Nov 12, 2007 | Adcom GCD-700 5-Disc CD Changer
250 people viewed this question
Ekse
 Grubhead
Grubhead
