Hi I need a stand for my 24 inch monitor/tv. I tried ebay amazon and acer and coulld not find anything. Any ideas?
SOURCE: monitor going to stand bye as soon as turned on
SOURCE: Acer 3690 wont display to LCD monitor or TV outputs
First check that the 22 and 32 ince monitors are plugged in. I know this sounds like a duh, but this can be overlooked easily.
If power is plugged in, check that these two monitors work by plugging in another computer with it..or with the tv, just plugging in. If they have power, move on to the next direction..
Check your cable and make sure you are using the correct cable with each. Check the connection if it is fully connected together. If the cables are connected and monitors do not show anything, the problem herein lies the cable. Get a new one!
let me know how it turns out!
SOURCE: Acer AT2001 cannot use as monitor
I currently own an Acer AT2001 21 inch Television/Monitor. The refresh rate on your computer should be set to 60Hertz. You can change this setting by right clicking the desktop, click properties, click settings, click advanced, click adapter, click list all modes, click 800by600 at 60Hertz. The screen resolution will not go above 800by600. Note; Initialize these settings with an old crt monitor and then plug in the Acer.
SOURCE: monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email [email protected] if you want pictures and costs
SOURCE: Acer 42" LCD AT4220B has vertical lines, need replacement Screen
you should get in contact with customer support for a possible replacement , try this link,
click here:
http://www.partmaster.co.uk/cgi-bin/catalogue.pl?section=159190&link_parent=159196&path=99178
