Question about American Standard Home
Toilet tank fills randomly, why is this?
Toilet tank seems to fill again after it has already filled.
    New Friend:
  • 22 Answers
Flapper seal is damaged or worn out. Replace Flapper with one for your model.
Posted on Nov 11, 2013
6ya staff
SOURCE:
Anonymous
  • 11 Answers
SOURCE: toilet fills up very very slow
REMOVE FILL LINE FROM VALVE. HOLD IN BUCKET AND TURN WATER ON, IF GOOD PRESSURE REPLACE COMMODE FILL VALVE. IF BAD PRESSURE CHECK FOR BLOCK ON LINE IT MAY HAVE SEDIMENT ON THE FILTERS.
Posted on Oct 27, 2008
Anonymous
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
Anonymous
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
gypsycat00
Joseph Weisenberger
  • 224 Answers
SOURCE: Once my tank has filled (toto toilet) the fill
The fill valve isn't adjusted correctly. Does it have a ballcock or a newer fill valve? If it's the ballcock, there's a screw in the middle of the fill valve that you can loosen to lower the ballcock. If it's newer, you'll see a float that surrounds the fill valve. It has a small metal clip toward the bottom that you need to pinch to raise or lower the float. It also has a large plastic screw with a phillips head at the top for fine tuning.
Posted on Jul 04, 2009
Anonymous
  • 10 Answers
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Posted on Nov 01, 2009
Where can I get a fill valve for Pegasus toilet
Use a fluid master universal fill valve, if it fits the tank. It will work as long as no part of the unit rests agains the side of the tank, if it does it will keep the float from rising.
Jul 03, 2014 | Pegasus Technologies Two-Piece Round...
Water supply to toilet fills up tank too slowly
Valve fully open on inlet going into toilet if it is then fill valve needs to be replaced check water line for any abstructions that might interfere with water going into tank.
Apr 02, 2014 | Kohler Home
It takes a long time to fill the tank
There could be partial blockage of the water supply line causing a slow fill.
Feb 20, 2014 | Kohler Cimarron Comfort Height elongated...
Uberhaus toilet fill valve will not open to let tank fill
Maybe something wrong with the mechanism inside the toilet fill valve. Try to adjust the fill valve first. I found this one about adjusting fill valve, I hope it can help you.
ADJUST MOEN TOILET FILL VALVE 5300 Home
If the problem remain after adjusting the fill valve then I will suggest you to buy a new toilet fill valve and replace with the old one.
Thanks.
Oct 06, 2013 | Home
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
My flapper was leaking, so I replaced it. Now, when I flush, the water leaves the toilet bowl, fills the bowl, and wants to flush again. All the water wants to leave the tank, but the toilet doesn't...
Reset the fill valve so that it does not fill the tank so full....this will be easier then trying to find a different flapper that will drop down faster, which is the only other thing you can do...
heatman101
May 15, 2011 | Plumbing
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
Tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
Dec 07, 2009 | Toto Drake ADA Compliant Toilet with...
Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Aug 01, 2009 | Kohler Home
Home Logo
118 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
