Sony Vaio VGC Rb-50, installed two 1 G sticks for maximum RAM. Tried safe mode and did disk check again but still the icons do not open.
First, remove the memory and replace the old memory, does the help? Be sure to unplug and REMOVE battery. Second, do a system restore to before this problem. Is the memory the exact type that was removed? Open the Task Manager and look for a process "explorer.exe" select and click on "end process", in the task manager open file, New Task (run..) in Create new Task type: explorer, click on OK.
SOURCE: sony vaio motion eye
I have windows vista sony vaio vgn fe880e buying at america, but I dont have drivers of motion eye web camera
SOURCE: Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
SOURCE: Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
You will need to get XP drivers for the product, they can be found here.
SOURCE: Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
