SOURCE: image shattered/double when moving.
check your antenna connection and auto-reprogram the channels.
SOURCE: My Toshuiba 46RV530U tv has developed an image
Sounds like you need to try reseating the lvds cables on the t-con board.This board is located at the top of the set in the center.You will have to remove the metal shield covering the board.Then you will see to flat cables connected to the board,one for each side of the screen.carefully unlock the connectors and remove and replace the cables.If this does not work you will need a new t-con board.I'm not sure about this particular model but sometimes the t-con board is only available as part of the lcd panel assembly.Good luck!
SOURCE: I have a Samsung HDTV (LN-T5271F) approx 4 yrs
Do these bands appear even when no input is connected to the tv? It will help us isolate whether its an LCD controller problem or a problem with the video processing circuits
SOURCE: tv screen became very light;
Is this LCD Flat panel TV? It sounds likelit has bad T-CON board, see example here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
