I own a TDD2 Kegerator Serial # 1-3336338 1/3 HP, 115 Volt / Hz - 60 / PH - 1 / F.L. Amps 8.5 Kegerator is clicking on and off...not cooling. I believe it is the relay to the compressor. What do I need to fix this and at what cost?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
