Remove the back lower left access panel. You will find the drain pump there. 95% of these problems that you have described is from the drain pump bearing going out. If possible, run the washer with this panel opened and listen to the pump. If the noise you hear is coming from there replace the pump with the new designed pump. Here is the pump to order. To replace the pump, tilt the washer back and remove the belt, then remove the two hoses from the pump and then the three screws that hold the pump on. If the pump is not the problem, post back to me.
SOURCE: high pitched buzz/whine during wash cycle only, spin fine
my new front load washer makes a high pitch sound when water is going into it
