My machine does not come on after I turn the control dial to setting and pull knob out nor any water . The motor does not appear to come on. The power cord is plugged into a working outlet, the water feed is on also.
It is possible that you need a new timer which is a part number: 22003362 and is usually about $75-$100 but it is also possible that one of the components of the knob is not functioning properly. The best bet is to take the knob apart (make sure the arrow points to a wash cycle first) and then pull up on the time timer shaft itself. If the washer starts then you know its one of the components of the knob that when bad. If it doesn't then you know you need a timer.
SOURCE: Maytag Dependable Care M# LAT9416AAE will not
It sounds as if the floating motor mount is no longer floating or the 2 springs inside of that floating / gliding mount are not working correctly. There are also 4 hard rubber clear washers that are part of the gliding mount. If any one of the 4 of those washers has broken the motor does not glide properly and will not tighten the belt properly for the spin cycle to work. Make sure the unit is unplugged reach underneath the left front corner and feel for a 2 V belt groved pulley. First push the pulley inward 45 deg from the corner and let it go.... If it is working properly it should automatically tension the belt. If is sticks in position the either the springs or washer have failed. This is not an expensive repair. IF you call for a repairman make sure he checks the condition of the tub drive belt. The motor has been placing undue wear on the drive belt due to it being loose.
SOURCE: I have a model #LAT8714AAE Dependable care plus
CHECK THE FUSE ON THE LID SWITCH BELOW THE TIMER. IF ITS BLOWN YOU NEED THE LID SWITCH ***.SOMETIMES EVEN IF ITS NOT BLOWN THE SWITCH IS BAD
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
SOURCE: Where is the reset button
there is no reset button, the reset for the system is to unplug it for at least 3 minutes from the wall socket, if it doesn't reset then there is a electrical failure of the central control circuit board.
SOURCE: I have a Maytag Dependable
It is a timer problem. There are tiny pins inside of the timer and obviously that part of is bad.
