First it shows as system is damaged...so repair drive or format drive........i formated the drive and then the recovery error 102 & error 104 displays...........pls give solution for this problem......
thank u
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
I wouldnt like to be dropping mine on the floor,unless there was no other option,you just got to be patient here and you usually find an answer.I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
it will come up with white screen again but this time it will start
Update you will see the progress bar moving wait until it is all done
and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
tremenda mierda
never got plugins i paid for now unit says recovery code 104
ERROR 102
recovery code 102
