Televison & Video Logo
kenya Posted on Nov 16, 2012
Ii'm trying to program a magnavox universal remote
  • King Drew
    King Drew Jun 21, 2015
    Used ge universal remote #24922 and first if anyone has tried prior u must factory reset by pressing setup once then mute once then #0 should blink twice,now here we go press setup once then tv once then power button once, now point towards Magnavox sdtv box until turns off which took me about 1 beer, 5-7 minutes. Now I recommend putting tape over any other devices that take remotes like DVD, tv,stereo etc as during process they will shut off and on frequently, so use tape to cover the sensor where u point remote on all
    devices except Magnavox Sdtv tuner! Enjoy and write down somewhere as if u need to reprogram its helpful!Enjoy!
How to use RCA Universal remote to program Magnavox SDTV Tuner
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
3helpful
2answers
Need to program a ge universal remote to operate a magnavox sdtv box model #tb110mw9 please get. The codes
There is no setup codes for magnavox SDTV box with this remote cotnrol. If you wish to get setup codes and other details to your SDTV box, check this link. There are setup codes to other brands of remote controls, by which you can select one, which have setup codes to your device.
1helpful
No remote have universal remote what are codes for magnavox sdtv
Hello
You haven't specified details about your Magnavox. There is Philips Magnavox and Magnavox. Anyway I'll give you codes for both Philips magnavox and Magnavox.
MAGNAVOX CODES
Three digit universal remote codes are
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 089/ 133/ 163/ 165
Four digit universal remote codes are
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
PHILIPS MAGNAVOX
Three digit codes are
183/ 184/ 208/ 213
Four digit codes are
0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
I need to know if there is a universal remote made for an emerson model TC 1369?
I tried three universal remotes an attempted to program them.
the one that worked was a Magnavox MRU 1400/17
The code was 0706.
it took me a while to do this, cost was 9.99 at K Mart
19helpful
2answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
