I cant go down to any list in my phone , menu , contacts logs ,anything but for example when i'm scrolling in a playlist and wanna choose a song at the bottom of the list the scroll go down beyond the screen and i can't see it but i can choose it and the song will play , really i can't fix this and i'm sick of this blackberry thing
Track ball assembly should be change by an expert
If you press and hold your menu button and get to your desired application (or use the convenience buttons) there are some applications where you can scroll using the spacebar (only between sections) if its a conversation press "t" (for top) or "b" (for bottom) otherwise if you want to scroll to a conversation you'll have to compose a new sms to desired contact and the extisting conversation will show up (for sms) and as for bbm just search the contact and click it. I had that problem with my curve and didnt even try to get it fixed in the beggining it would do that occasionnally but eventually it just failed completely so i bought the bold. You can try getting it fixed but nothing guarantees it wont happen again. hope this helped
I have the same issue, started today evening suddenly. I had reboot my phone just like that and then this problem came. I was like WTF.I can not scroll down in any section :( or if you you are already in bottom you can not go up, can not scroll huh, then have to move with thumb like shooosh and then suddenly another movement happening like like page up down but its really annoying. I also downgrade the OS from 7.1 to 7.0 Didn't work and i also installed fresh copy of 7.1 still having the same problem :S seems it is issue with TRACKPAD ........ but how come on a reboot of phone? freaking blackberry have some kind of very strange behavior of things and no fix for that. Raj
SOURCE: When I turn on my
Try to make MASTER RESET manually. If failed, upgrade sotware from any skilled mechanic.
Supriyo DG
SOURCE: trackball
I just had this happen to me. I blew air (from an air can used to clean keyboards, etc) into the trackball and it started working fine. It seemed there was dust or something stuck inside. Good Luck!
SOURCE: So randomly today the o
If it got water it needs replacement of a few parts, you need to take it in for repairs.
SOURCE: scrolling
seems like either your cell phone's OS has been corrupted or there is some problem in your memory card , try to remove your memory card and try to scroll the songs again , if its working properly then the fault is with your memory card , or else your operating system .
P.S:- out of curiosity how many applications are you running with the mp3 player because sometimes if you run to many application simultaneously it tends to exit other applications .
hope this helps
SOURCE: I can't scroll up or down and sometimes the phone
dear,
open the casing of your phone and clean the key pad specially the left/right, up/down keys.....and then check it...
Dont use any contact cleaner or other liquid without removing LCD please... the spray will damage the screen...
regards,
