Cooktops Logo
Anonymous Posted on Nov 15, 2012
How to fix a crack glass table top
Glass top is about 1" thick and imported from Italy.
2 Related Answers
Anonymous
  • 413 Answers
  • Posted on Jun 10, 2008
SOURCE: glass top repair
Replace the glass top...
Anonymous
  • 472 Answers
  • Posted on Jan 21, 2011
SOURCE: My glass cooktop has cracked
most of the time for this to happen something would have had to been dropped or excessive weight on the unit ... it is possible over time the unit had a unseen hairline crack and the heat has caused it to become worse... the glass for these units are ridiculous in cost but can be repaired...
several online sites sell parts.... a few reputable companies are
www.sears.com
www.apdepot.com
www.repairclinic.com
1helpful
Need new glass top schott hob
You need to buy the new glass top without the elements, there is no fixing it, or should not be fixed, it should be replaced.
Apr 09, 2013 • Cooktops
I have a crack in the glass top cook top across the left front cook area. And this be fixed?
Hi glors732,m
A chip perhaps, but not a crack, you will need to replace the whole glass panel. Will be quite expensive though.
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it.
2helpful
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
My glass cooktop has cracked across the top left corner. It has created a triangle, about 1-1/4 inch on each side. Is this a flaw in the glass?
www.sears.com
www.apdepot.com
2answers
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
1helpful
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
2answers
Glass top repair
1helpful
3answers
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 • Cooktops
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
