Question about Whirlpool Microwave Ovens
In oven the start button is not working - Whirlpool Microwave Ovens
    Top Expert:
  • Whirlpool Master
  • 12,223 Answers
See the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Posted on Nov 16, 2012
6ya staff
SOURCE:
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
Panasonic nn-c781jf start button not working Microwave Ovens
Microwave ovens are very complex to work on. You may have a defective door sensor, which will prevent the oven from starting. This is the most common issue.
Nov 11, 2015 | Panasonic Microwave Ovens
Microwave doesn't work after press the start button
Blown fuse inside the oven. If you can do electrical work, repalce it. I wrapped mine in aluminum foil as a quick fix, as I understand the very high risk of fire and possible death from doing so.
Nov 21, 2013 | Sharp R-408J Microwave Oven
Some of my buttons will not work
It might be time to get a new microwave oven. I would check out http://bestmicrowavereview.com before making any purchase decisions.
Jan 03, 2013 | Goldstar MA-780M Microwave Oven
Only certain buttons of microwave oven touch pad work.
Hi, welcome to Fixya!
From your question, I suspect the fault is from the control board of the microwave. This is why some buttons on the the touch-pad are not working.
Have the control board replaced and the buttons that refuse to work will start working again.
I hope the above is clear. If not, please let me know.
Regards.
Nov 17, 2011 | Microwave Ovens
My daewo microwave oven Kor 860A start button doesn't work or function.
Possible that the pad is not working or a possible failure.
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
If only the start button is inactive but you are able to set timing then then the start button pad must be worn out.
Nov 08, 2010 | Daewoo KOR-860A Microwave Oven
Start button
I have a related problem, my Siemens microwave/oven as soon as I press the start button brings down the fuse. I put up the fuse again, the clock is working, the light inside as well, but as soon as I set the microwave on and press the start button, it brings the fuse down again. Is this a problem with the siemens microwave or with my electrical installation?
Jan 09, 2008 | Microwave Ovens
The start button of the keyboard does not work
I would first suspect the door switches. The door must be shut and the switches must be working before the contoller will let the oven start cooking. See my other answers for a text file on door switch testing and replacement. Once they have been checked, if you still have toruble, please reply back.
Dec 10, 2006 | Welbilt MR99T Microwave Oven
Microwave Ovens Logo
830 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
