This happen because the LACK of LUBE , you must LUBE every 5 hours aprox from use. The design shut down the machine for protection electronic. Now lube.mAYBE YOU have a WORN deck belt and need replace.
2) LUBE the rollers bearing too.
3) Test the main motor bearing and replace if necessary.
God bless you
Just recieved lube kit. Machine had some dust and a few "belt chunks" but small ones. applied lube and tried to run machine, same thing. other suguestion was to test main motor bearing. How do I do that?
