Question about Motorola Mobility H3 Bluetooth Headset, Black Headset
Motrola h350 driver for windows 8
Headset will not work in windows 8
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
H350 does not work as audio device
I was able to use my Motorola H350 Bluetooth Headset on Windows 7 by installing the drivers found in this link: http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Good luck! It took me about a week to find the solution.
Aug 20, 2009 | Motorola Mobility H350 Wireless Headset
H350 will not work on pc
there is no need for the driver
just follow this
ok here u go first turn on the bluetooth func in ur laptop, now while ur bluetooth haedset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the bluetooth software there is an icon in the taskbar bluetooth right click and take properties search for blutooth devices there ur headset will come up like motorola h550 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try the sound settings in the taskbar or play music u will hear it in ur headset
pls rate me FIXYA for this
Feb 22, 2009 | Motorola Mobility H350 Wireless Headset
Trying to add a h350 to my new phone
http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/H350/US-EN/_Documents/Static%20Files/H350_QSG.pdf
to put the h350 in discovery mode , hold the main button down until the light stays on solid , it does take several seconds , and there is a window time limit , get your phone ready and put h350 in pairing / discovery mode , see if your phone picks it up . if you need help with the phone ,
http://downloadcenter.samsung.com/content/UM/200806/20080603015152281_alltel_r430_myshot_ug.p
Dec 30, 2008 | Motorola Mobility H350 Wireless Headset
Maual for Motorola H350 bluetooth headset
Hi - You can download the manual from the link underlined in blue below:
Motorola H350
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 18, 2008 | Motorola Mobility H350 Wireless Headset
Need more volume for M H350 headset
There is also a setting in the phone for the headset volume. Under Sound settings.
Mar 10, 2008 | Motorola Mobility H350 Wireless Headset
Pin code roe my H350
i forgot the code to my motorola h350 headset and wondering if you could give me it
Feb 15, 2008 | Motorola Mobility H350 Wireless Headset
H350 headset no sound
I had the same problem and ended up exchanging my H350 for another one thinking the unit was defective. I had the same problem with the second one so I tried turning the phone completely off as well as the headset....then powering them both on. Worked like a charm. Apparently the phone just needed to be reset. Hope that helps.
Feb 09, 2008 | Motorola Mobility H350 Wireless Headset
Motorola Mobility H3 Bluetooth Headset, Black Headset Logo
49 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
