Question about Rolex Watches
Rolex 6694 date and time instructions manual - Rolex Watches
6ya staff
SOURCE:
indays
johnny medrano
  • 111 Answers
SOURCE: rolex watch
if your watc is automatic or self winding,you need to use your watch at least 12hours a day,to set the time , wind the crown counter clock wise,until the crown lose then full the crown to set the time,after setting the time fush the crown then wind it clockwise to lock again! thank you !
Posted on Aug 27, 2008
Anonymous
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
unscrew the winding pin until it opens to the first position. (this position is for self winding. approx 30 turns clockwise will fully wind the watch)pull pin to the next position. this sets the date if it is a quickset. 1985 to present. again turn clockwise to the desired date is present. pull the pin to the final position and this will set the time turning clockwise as well. hope this helps.
Posted on Jan 05, 2009
Anonymous
  • 43 Answers
SOURCE: unable to manually change date on my Rolex Oyster
Usually to change the date you need to have the crown pulled out to a position that is between the "closed" position and the position where it will move the minute/second hands.
Anonymous
  • 43 Answers
SOURCE: rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Anonymous
  • 26 Answers
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Posted on Jan 06, 2009
I got a president day date rolex, sometime the date jump twice in 1 day
Reset the time, day and date manually from scratch. Check for another 24 hours. If the problem persists that means there is interference between day and date wheels and in this case you will need watchmakers help, as to correct such a fault the watch needs to be disassembled almost completely.
Feb 24, 2011 | Rolex Oyster Perpetual DayDate 18kt Yellow...
How can I change the time and date on my wife's Rolex? The stem will pop out but nothing happens when I turn it either way. No change of date or time.
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
Nov 25, 2009 | Rolex Submariner 16618 Wristwatch
Winding and setting the time on a rolex watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Apr 04, 2009 | Rolex Watches
I need an owner's manual for a Rolex Oyster Perpetual Day-Date. Any idea where I can locate one?
Mar 31, 2009 | Rolex Day-Date President 118238 Wristwatch
Owners manuel
There isn't any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
PS: If you do not have Day function, just ignore it - the rest is the same.
Mar 18, 2009 | Watches
How to adjust day date on older rolex perpetual day date watch
Mar 06, 2009 | Rolex Datejust SS
Does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
2) when you pull out the crown to the first click, it is in date setting position,
Feb 03, 2009 | Rolex Datejust SS
My date just will not set, it clicks two times but doesn't move
it's time for a overhaul and cleaning...the stem may be worn out. Rolexs need this service about every 10 years.
Jan 18, 2009 | Rolex Day-Date President 118238 Wristwatch
Dec 12, 2008 | Rolex Datejust SS
Setting the independent hour hand on a Rolex Explorer II
It should be the 3rd position on the crown: 1st date, 2nd hour, 3rd time zone. And don't take it to a "jeler" like jamison said. If you cannot do this watch is fake.
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
Watches Logo
330 people viewed this question
Top Rolex Watches Experts
Janelle Schoonover
Janelle Schoonover
Tom Lambert
Level 1 Expert
Are you a Rolex Watch Expert? Answer questions, earn points and help others
