When i go to Set up USB game controllers in Control Panel and go to properties for PC TWIN SHOCK to check if its working fine first i tried the left joystick and it worked nicely but when i moved the right joystick it was like pressing the buttons "4" "2" "3" or "1" if there is a way to fix this please help me
SOURCE: My xbox 360 wont synch with my controller even if i tried pressing the buttons
It could either be one of 2 things , your controller is knackered or the wireless board where the power switch is mounted could be faulty, try a mates controller and see if it does the same.
jonno
SOURCE: Xbox 360 controllers not responding
read this guide,that should help..in short you need to press the connect buttons on the controller and the console..see the guide for diagrams
see this http://assets.xbox.com/en-us/support/na-controller-wireless.pdf
SOURCE: Wireless controller is constantly moving down
One of two things. First, when you turn on the power, do not have anything pressing against the joysticks. It will sometimes cause the problems you are describing. If that is not the case, I would assume you got something stuck under it or spilt something on it. Good luck.
SOURCE: It won't do anything at all
one option is to buy the official microsoft PC/ 360 controller.
I looks exactly like a regular 360 controller, but it comes with a small receiver in which you will be able to interact with the PC as well.
