Yes. Follow the instructions on the bottom half of page 14 of this manual.
SOURCE: Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
SOURCE: How to programme quick dial feature
to memorize:
buttons > 2 > # > auto-dial/store > exit
to recall:
just press button
Chris
SOURCE: Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
dial 705
I.e. once in 705
Type in speed number, the cursor will tab over to speed dial slot.
Enter 9 followed by the phone number.
Press 12th button down,
Enter name,
Press 12th button. (You will be back at the speed dial.)
Press tab, then enter the next speed dial slot you wish to program.
NB-
( 705 - Speed dial 12th Button down to toggle between)
( 706 - Speed Name the 2 MMC
