Change the battery. This is the first step when troubleshooting a
ceiling fan remote. The easiest fix to any remote control problem begins
with battery replacement. A 9-volt battery is needed to operate all
Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found
on the wall must be in the "on" position. This allows the ceiling fan to
be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working
again, try to reprogram the remote. Open the battery cover you will see
4 dip switches. These switches must be set to the same position as the
receiver on the fan. Use the screw driver to move the dip switches
either up or down.
Follow the previous step to change the frequency if the ceiling fan is
randomly turning on or off. Other electronic devices such as garage door
openers can interfere with the ceiling fans receiver, causing it to
randomly turn on or off.
I have the same problem. Fortunately/unfortunately, I have another of the same model in another room. I used that remote and I now know that the fan and lights work fine. It's the remote that is broken, but I have no idea why. I have tried new batteries, and am now looking online for a replacement remote.
