New just installed --easy to do-- makes awful nooise isolated to left fan. The eschaust fans are normal. The right fan is visible and is quiet. The left fan which is haeder to see is the one that seems to ake the noise.
Got it 3 days ago as a floor model, still has warrantee. All else works perfectly.
SOURCE: Microwave on its way out?
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: New Microwave not working
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If it's still not working, you'll need to contact your nearest Panasonic-authorized servicer.
SOURCE: Have a Panasonic Microwave/Combination
I could not find your exact model but please check out the link below and download the one that is closest to yours.
Hope this helps. good luck
http://www.panasonic.ca/english/customercare/downloads.asp
SOURCE: We have a Panasonic Microwave.
This not good! from your description the problem is in the keypad controller, on the back of the keypad is a circuit board that contains the microprocessor and additional parts that control vital areas of the microwave oven. The leak has penetrated the vital areas where the electronics are housed, I suggest you replace the microwave oven because the cost will probably more than what a new one will run.
Panasonic NN-H275 1100 Watts Microwave Oven
fan left upper makes grating noise. New just installed.
Please reply back with your brand and model number so we can help you.
