HP Compaq Business d530 PC Desktop Logo
A
Anonymous Posted on Nov 13, 2012
How to solve this problem 163 - Time and Date not set The system time is invaled. This may be a result of a loss in battery power. Set the correct time and date using your OS. If this mesage persists you may want to replace the onboard battery. The following configuration options were automatically updated: CD-ROM: SAMSUNG CD-ROM SC-148A Disk :40.0GB Samsung SP0411N If you are running unix, You need to configure your system using the computer setup utility (F10) HP DC5000 SFF(PB475A)
1 Related Answer
Anonymous
  • 111 Answers
  • Posted on Feb 17, 2010
SOURCE: My desktop compaq sent me a message stating that
you need to replace your cmos battery, you need to open up the casing of your computer. you need to look for the coin cell battery on the motherboard, there shoulb only 1 there, so you cant miss...
1helpful
Error 00161 and 00163 on my IBM Thinkpad 770
Please find below the error on your laptop, i read it on other forum and it says that error 161 is a dead battery while 163 is a timer that was not been set properly.
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Numeric error codes index - ThinkPad 600/E/X
hope it helps..
2helpful
Hello my ibm thinkpad 600E will not come up. it says error 00161 and 00163. what do i need to do?
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date, bootup order, etc, and reset. I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
backup battery = CMOS battery
According to the error codes, you have a dead backup battery and the time is not set. Error: 161
2. Backup battery.
3. System board.
Error: 163
2. System board.
12helpful
What is error 00173, 00192, and 00163
Error 192 means a fan error, to test this measure the voltage of the backup battery. If the
voltage is not correct, replace the backup battery. Check the fan and the system board.
Error 163 means the time and date is not set, to set the time and date hit F1 when you see the IBM logo and set the time and date.
Error 173 means the configuration data is lost, to sort that select OK in the error screen and set the time and date.
In most case its the CMOS battery that's run low and need to be changed for a new one, so for the time being you will have to keep setting the time and date and it will boot to windows.
Good luck
It says there are error codes 163, 8611, and 163 time and date pop up but if you try and pass that it freezes and shuts down again. please help
The 163 error is a BIOS Date & Time error. Go tinto the BIOS setting and set the Date & Time. If you boot up the next time and you get the same error, this is cause by a flat BIOS battery, replace with a new battery.
The 8611 error relates to the PS2 mouse bus connector, try a new mouse or use a USB mouse.
1helpful
2answers
162-System Options Not Set; 163-Time & Date Not Set
The bios settings are being lost during offtime. This is due to the cmos battery being dead. Most units have a round 3-volt lithium battery in a clip/holder. A few use a rechargeable battery that recovers if the unit sees frequent use. Can you verify the model number of this unit?
3helpful
Every time I log on the error173 and 163 appear. What do I do?
Your BIOS backup battery is dead and needs to be replaced.
Go HERE for the manual , page 67.
And HERE is a link to the battery, or google 02k6502 if you dont like the price.
If that doesnt do it , its the motherboard.
Here are the codes from the manual.
163
2. System board.
173
(Configuration data was lost.)
1. Select OK in the error screen; then set the time and date.
2. Backup battery.
3. System board.
Hope that helps.
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
2. System board.
173
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the voltage is not
backup battery.
3. Fan.
4. System board.
Error
I do not think you fixed the CMOS battery - (backup battery = CMOS battery) According to the error codes, you have a dead backup battery and the time is not set. Makes sense? 161
2. Backup battery.
3. System board.
163
2. System board.
hope this will help.
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
