Whirlpool built in dbl oven RBD305PDB14, will beep several times and the code displays, then the display will go blank. You can still push the buttons and they will sound but you can not use the oven only the minute timer, without a display. Then sometimes the display will come back on and function normally.
When ever you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty control board.
Your control Board # 4452890 is not working as it should be. This control board is not available for purchase from Manufacturer.
Either get the Control board repaired or buy a new appliance.
I would suggest www.partsimple.com to get the board repaired. They have the lowest repair cost as compare to other online vendors.
Here is the direct link for the control board: http://www.partsimple.com/4452890-wpl-r-12.html
Whirlpool KitchenAid Range Control Board Repair Service 4452890
E6/F2 is always the control board. It can be repaired quickly and reliably. www.fixyourboard.com
SOURCE: F2 E6 on Whirlpool RBD305PDS14 double wall oven
Sometimes we see an intermittent electrical connection due to oxidation of the contacts on the keypad membrane tail. This can be easily cleaned so you can check this before investing in a new keypad. I posted some pictures and the procedure on our website. Here's the link:
http://fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
SOURCE: Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
SOURCE: My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad
(also called touch pad or membrane switch). Some models incorporate keypad
in to control board as one unit. In this case, replace control board (also
called ERC or clock).
SOURCE: error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Identical problem with the blank display and some beeps
